Skyjack 1998 4626:
fast lower in lower mode
New to this forum hopefully someone can help me with this. I just purchased this lift its in really good shape for its age with only 150 hrs on it. The lift goes up nice and smooth but when I go to lower it there is no feathering at all it just basically drops everytime you pull the lever. there is plenty of fluid in it it just seems like theres a valve or something that is stuck and lets the oil return to fast to the tank.
Any ideas?
Thank you
Bart
  • Posted 15 Apr 2024 00:24
  • Discussion started by Bart_Curtis
  • Washington, United States
If you need additional help, just ask, I'm someone who likes to share knowledge of lifts, after 25 years of working on them, and mostly Skyjack, might all well!
  • Posted 21 Apr 2024 15:20
  • Reply by Matthew_Reed
thank you for the info ill give it a try
  • Posted 21 Apr 2024 09:46
  • Reply by Bart_Curtis
Sounds like the down valve is worn out, the valve is located on the hydraulic manifold and is the one with wire #13 controlling the coil. Could also be coil or power to down but most likely the valve. Go online to skyjack.com and download service and parts manuals see if any valves are the same part number to swap, maybe brake cable and coil, then swap, if issue is better order new valve for brake or whatever you swapped
  • Posted 21 Apr 2024 06:04
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
SMV (Konecranes) 16-900C
Mobicon 2T
