event code 306
what is the reason for event code log in 306 RR 5700and hydraulics and traction disabled condition, please help
  • Posted 21 Aug 2020 01:20
  • By vava_1977
  • joined 22 Sep'17 - 6 messages
  • kuwait, Kuwait
BINESH
Did you find a solution on this? Having same issue over here. Thanks
  • Posted 31 Oct 2024 04:51
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
thanks ,let me check
  • Posted 30 Aug 2020 02:23
  • By vava_1977
  • kuwait, Kuwait
BINESH
No, it should be 60 ohms. Reconnect Access 5 and disconnect Access3 and test at Access 3 connector. If 60 ohms the fault is Access 3, if still low then either wiring or a different Access unit.
  • Posted 29 Aug 2020 11:34
  • Modified 29 Aug 2020 11:36 by poster
  • By techno_nz
  • Canterbury, New Zealand
Thanks for your reply, Access 5 connector disconnected and RESISTANCE found 37 ohms only, is it acceptable or not
  • Posted 28 Aug 2020 00:28
  • By vava_1977
  • kuwait, Kuwait
BINESH
Access 5 communication fault with Access 3 on startup. You need to do a CAN test.
  • Posted 27 Aug 2020 19:50
  • By techno_nz
Terberg RT223
Crown RD572513TT6860R
Zhejiang UN Forklift Co., Ltd
