ETV216 problem
I have a problem with a jungheinrich ETV216 91010601.Every hydraulic moovement we try the truck lifts the fork. I mean that when i use the tilt lever the truck lifts, same with the rest of levers.Any ideas?
  • Posted 21 Feb 2014 00:31
  • By tasos_t
  • joined 20 Jul'13 - 259 messages
  • ATTICA, Greece
Hello Tasos
First tell us do you have multipilot or solopilot on that truck for hydraulic commands.If is multipilot that I was see in most cases can you tell me did your hydraulic multipilot works ok?
If he is good and you dont have error on display it is important that you check wiring on hydraulic block and make sure that wiring is not defective or some electric valve is not working.If all what I write to you is ok than your hydraulic block is problem and you need to replace it or service.Probably some valve is stuck and hydraulic mix function.
Hope this helps to you.
good luck
  • Posted 21 Feb 2014 09:28
  • By nemanja_k
  • serbia, Serbia
Terberg YT223
Hoist Liftruck F180-36BOX-CAR
Zhejiang UN Forklift Co., Ltd
