ETV16 GE WILL NOT DRIVE
Hi all,
I have a jungheinrich reach truck that will not drive, no error code comes up on the dash, the foot switch bells out ok, has anybody got some information they are wiiling to share, the hydraulics works okay,
model ETV16GE 100.710 dz
ser 80070178
type no 8453072
  • Posted 18 Sep 2010 18:18
  • By peter_d
  • joined 4 Jun'09 - 50 messages
  • manchester, United Kingdom
Thanks again Nuna, the fault did turn out to be the pedal, ordered new and fitted truck now working.
Pete
  • Posted 24 Sep 2010 04:43
  • By peter_d
Thanks Nuna for the info. It could be Tuesday before I can get back to the truck, I will post a reply with the results.
Pete
  • Posted 20 Sep 2010 02:44
  • By peter_d
Hi,
No the truck will not drive at all but will check switch any way.
Pete
  • Posted 20 Sep 2010 02:41
  • By peter_d
Id check the battery lock switch is ok first, just because the light isnt on the dashboard doesnt mean the switch is in good order, does the truck drive in snail mode, it should do even if the battery is out.
  • Posted 19 Sep 2010 21:53
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
Hi, There are 3 pins connected to the acc. potentiometer : one (X65:2) for GND, one ((X65:4) = 12 VDC and one (X65:5) = Acc. signal : Using the meter to connect between (X65:2) & (X65:5) it should be = 1.2 - 2.56 VDC when Acc. pedan in Zero, and 9.4-10.8 VDC when full pressing the pedal to max.
* Using the Ohm meter to connect between (X65:7) & (X65:9) loacted under the pedal to check the pedal sw => it must be = 0 Ohm when pressing the pedal.
* Using the Volt meter to connect between (X54:2) loacted around the foot SW against one of the positive pole to check the deadman/foor sw => it must have 0 VDC at this pin when pressing the foot sw.
* Using the Ohm meter to connect between (X51:4) against (X51:1) & (X51:2) located around the direction SW in order to check this sw => it must be = 0 Ohm when pressing the SW.
Let me know your checking results
Good luck and rgds
  • Posted 19 Sep 2010 18:28
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Hi,
Do you have to take the foot unit off to check for broken lever or can I use a meter to check if the switch is working on the connection plug, if you can do you know the pin numbers on the plug to check.
thanks Pete
  • Posted 19 Sep 2010 06:52
  • By peter_d
For start should check the potentiometer throttle lever.Mostly roller lever break.
  • Posted 19 Sep 2010 04:19
  • By mosu_r
  • joined 22 Jul'10 - 12 messages
  • olt, Romania
Hi,
Your truck was produced in 1994, it is an old model but I think the controller is smart enough to alarm the error code if it really has problem. In your case, the truck has no drive and no error code this means the truck is missing one of GND singals for the drving enable condition which is not a serious problem. Please check carefully the following posibilities : deadman/foot switch, direction switch, contactor tip, pedal or accelerator switch, check if the brake is blocked,....
Good luck
Nuna
  • Posted 18 Sep 2010 20:48
  • Modified 18 Sep 2010 23:48 by poster
  • By Nuna
  • BK, Thailand
Thanks & Regards
Nuna
Taylor TX175
New - Sale & Hire
Big Joe PDR30-154
USD7,500
Taylor TX175
New - Sale & Hire
Big Joe PDR30-154
USD7,500
