etv 216 098 code
hi have intermittent 098 code on steering of jungheinrich etv 216 ac system code only occurs when wueel in certain position help appreciated thanks
  • Posted 14 May 2009 04:54
  • By sullyamg
  • joined 13 Mar'08 - 9 messages
hi nuna checked and clean as a whistle wiring and connctions seem ok distance appears good but is there a set gap i need to check to see if its within a tolerence
  • Posted 19 May 2009 04:56
  • By sullyamg
thanks nuna will check monday and let you know
  • Posted 17 May 2009 02:28
  • By sullyamg
Hi Sullyamq,
The code 98 means the steering problem : check the wiring and proximity switch, check the distance from the sensor to trip cam. Open the seat then open the plastic cover under the seat and you will see this proximity switch is located in front of the traction motor sometimes it is blocked by foreign material,... Let me know your checking results
Good luck
  • Posted 17 May 2009 00:03
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
VETTER Forks, Inc.
Terberg RT403
SMV (Konecranes) 4632CC5
VETTER Forks, Inc.
VETTER Forks, Inc.
