Error Message
The dash display says "Hoist cutout" and the second stage does not rise. Only the firts stage. Can you help with this fault?
  • Posted 21 Nov 2012 12:35
  • By hector_v
  • joined 17 Nov'11 - 42 messages
  • Puebla, Mexico
Saludos
hectorvargasm@msn.com
The mast is tilted forward, level the forks by tilting back and raise it. It is a safety mechanism to avoid raising is a forward tilt that can cause the load to fall forward.
  • Posted 7 Feb 2025 02:02
  • By will_v
  • joined 14 Apr'18 - 6 messages
I just had this happen. I had the tilt full forward so it wouldn't allow the mast to raise.
  • Posted 28 Nov 2022 18:48
  • By Gerald_Robinson
  • joined 28 Nov'22 - 1 message
  • Iowa, United States
Gerald L Robinson
Thanks Truck Tech, I re-calibrating the tilt sensor and the tilt worked.
P.D. swoop223 this unit has not a folding overhead guard. Only overhead guard. Thanks
  • Posted 25 Nov 2012 05:37
  • By hector_v
  • Puebla, Mexico
Saludos
Did you try re-calibrating the tilt sensor?
  • Posted 24 Nov 2012 14:03
  • By Truck_Tech
  • United States
no overhead guard? and you plan on lifting this over the top of mast height?
i think i'd be putting the OHG back on it
bypassing this safety feature just to get the mast to lift higher would be irresponsible.
  • Posted 23 Nov 2012 23:50
It had an overhead guard in place in the past when it left the factory (and 'safety for the operator' says it should have a GOOD overhead guard in place still unless you don't lift over the height it is raising to now), and it should still have some wires that used to go up the overhead guard to switches (both sides, as I remember) that told the system that the folding overhead guard was in place to be able to protect the operator from falling objects lifted above his head. when the guard was folded down, it allowed operation in a low overhead, and prevented lifting above a safe level. "Hoist cutout" is the message it gives when any one of those switches did not see it's position as having the overhead guard properly locked in place.
  • Posted 23 Nov 2012 22:46
  • Modified 23 Nov 2012 22:51 by poster
Thanks for the reply. This unit has not a overhead guard
  • Posted 23 Nov 2012 01:18
  • By hector_v
  • Puebla, Mexico
Saludos
?this unit has a folding overhead guard?
make sure the guard and the switches for the guard are in the full up position.
  • Posted 22 Nov 2012 22:29
Please!!!! Help me Somebody
  • Posted 22 Nov 2012 12:15
  • By hector_v
  • Puebla, Mexico
Saludos
Toyota 8FG25
Taylor T520S
