Error codes
Hi,
I have a Stand up Raymond forklift with deep reach. Lately, it started showing error codes like Code F4, Code F5, Code L1... Does anyone know from where I can get a list of these codes with explanation?
Best regards.
  • Posted 22 Jul 2008 23:33
  • By kamel_b
  • joined 22 Jul'08 - 1 message
  • Minnesota, United States
G3 looks like ur proximity sensor can be damage. 44 and 2U is your motor wires that connect to traction amp and you also will need a traction amp.
  • Posted 18 Nov 2023 07:41
  • By D_Lopez
  • joined 25 Apr'22 - 8 messages
DLopez
Dear Sirs,
Hope you help me because i have big problem with electric forklift OM XE 15 3AC. There is error code 64 and 120, also 245. Please send me some info what are meaning this codes and how can i repair it. The machine works like turtle and after 3 meters - power off. On the display there is 64 error code. Please send me some info.
Hope you help me. Thanks in advance and Best Regards!
  • Posted 21 Oct 2011 21:32
  • By krasen_s
  • joined 21 Oct'11 - 3 messages
  • Sofia, Bulgaria
Hi there guys. Met with some error codes on Raymond reach trucks. Can someone share the manual or give some light to the error codes on Raymond
error code G3, G5, 44, 2U
Have no access to the code manuals.
Thank you guys
  • Posted 30 Dec 2010 14:01
  • By steven_kuan
  • joined 21 Feb'06 - 1 message
  • Malaysia
BT Cargo CBE25 s/n CE233085
Need help with error code 59
Аnd yet I'm looking for a service manual for this forklift and if so, error codes
  • Posted 28 Sep 2010 22:30
  • By mikle_k
  • joined 28 Sep'10 - 1 message
  • Moscow, Russian Federation
need help with error code E Ad-1 lift will not start
  • Posted 6 Nov 2009 05:56
  • By richardj
  • joined 6 Nov'09 - 1 message
cat model n0r30
s/n 2m6-00182 i dont have the battery i thin is 36 but the code i have is code 80
  • Posted 6 Apr 2009 12:50
  • By angel_v
  • joined 6 Apr'09 - 21 messages
angel
give the model and serial number of truck, maybe i can help you the voltage and battery capacity thank you,
  • Posted 21 Feb 2009 10:20
  • By zarci
  • joined 16 Feb'09 - 31 messages
  • ncr, Philippines
cesar
I also have the same issue with a code F5 on a reach. The model is a EASI and serial number is ET-B-94-00986. This unit is a 24 volt system.
It turns on, and goes through the testing cycle, then it codes F5. I notice both contactor tips are fairly burnt and they both pull in, but after 2 to 3 seconds of it pulling in, it codes out.
Anyone has any suggestions or what this code means.
Thanks.
  • Posted 27 Jan 2009 00:18
  • By BusyE
  • joined 18 Dec'08 - 44 messages
As a former Raymond tech I understand your problem. Do you still have the problem or has it been solved? Before I anger the Raymond Gods of Forklifts by giving out private information. Understand Raymond is very proprietary and defends their territory. Hopefully Toyota will help them become more service friendly.
  • Posted 1 Dec 2008 07:16
  • By Submariner
  • joined 1 Dec'08 - 7 messages
Veni, vidi, vici.- Julius Ceasar
Value an honest mechanic, he earns his pay.
for the toyota the BT i am not shure i will keep my ears open
  • Posted 4 Sep 2008 14:32
  • By dantheman
  • joined 4 Sep'08 - 18 messages
  • New Hampshire, United States
Ok looks like u have a communication problem between the SCPU and The CPU. Does the truck have SAS? Check the PS contactor next to the F3 Fuse if that contactor dose not pulls in quick enough it will cause that code do u have a wire diagram? because if its not that contactor u will have to check voltages between the CPU and the SCPU sounds like a wire break but may be earthier the CPU or the SCPU
  • Posted 4 Sep 2008 14:31
  • By dantheman
Anthony, You must give Model and Serial # for all questions asked. It's like asking, do you have a stater motor for a FORD Vehicle. Giving us that information will help us help you
  • Posted 30 Aug 2008 22:59
  • By Prentice
if youre a tech
raymond will sell you the book (theyre actually not horribly expensive i think i paid 85 for mine)
then youll have to pay them a service fee to come out and reset the PW or you can change the eprom (i forget which but theres a hardware swap that will default the PW)
id imagine hes working on an EASI reach
  • Posted 26 Jul 2008 04:11
  • Modified 26 Jul 2008 04:11 by poster
  • By justinm
Greetings, What is your model #?
  • Posted 25 Jul 2008 10:38
  • By Stephen
  • joined 25 Jul'08 - 1 message
  • Virginia, United States
UN Forklift FBT18NQZ1
Crown RD572513TT6860R
