Error codes T230 and T231
Every now and then when starting this unit it will show both T230 and T231 at the same time. All functions but travel will work. Got to shut it off and restart it. Sometimes need to restart it 3-4 times before it will go away. TPS communication ?. I don't have another good working switch to use for testing. Any other way to test. Thanks.
  • Posted 23 May 2025 12:18
  • By Hein
  • joined 23 May'25 - 4 messages
  • North Dakota, United States
Hein Terblanche
Same way as I did. Buy a canbox off eBay that an ex Linde employee is selling.
  • Posted 21 Jun 2025 03:28
  • By andrew_k
  • joined 17 Mar'07 - 365 messages
  • England, United Kingdom
Maybe he can the software online but how is he going to connect to the truck fella??
  • Posted 21 Jun 2025 02:17
  • By lifter01
  • joined 4 Jul'09 - 465 messages
If the pot is faulty you may get away with just replacing it without calibration, you can get the software online ;)
  • Posted 2 Jun 2025 08:03
  • By andrew_k
You need to plug in a laptop with LSG installed so unfortunately you'll need yo get a linde tech to calibrate if for you
  • Posted 2 Jun 2025 05:08
  • By lifter01
How do you calibrate ? Thank you
  • Posted 27 May 2025 15:32
  • By Hein
Hein Terblanche
Plz send feedback problem solve or not slove
  • Posted 27 May 2025 15:24
  • Modified 27 May 2025 16:43 by poster
  • By SUBHASH_BHOSALE
  • joined 10 Aug'20 - 2 messages
  • MAHARASHTRA, India
Is there a way to test to verify faulty t-pod. If i install a new one how would i calibrate. Thank you
  • Posted 27 May 2025 15:13
  • By Hein
Hein Terblanche
Faulty throttle pot will need replacing and calibrating easy job to do and a very common fault on all Lindes
  • Posted 25 May 2025 22:41
  • By lifter01
Accelerator (reference signal): broken cable or short-circuit
  • Posted 25 May 2025 17:47
  • By vittek
  • joined 2 Dec'08 - 7 messages
  • Kharkov, Ukraine
