Error codes 5A and 59
Does anyone have any luck with resolving this issue?
Not intermittent, code 5A appears when switched on, after self-test and horn beep code 59 appears. Troubleshooting steps passed, suggests replacing both TPA and LPA(unlikely solution) Wires are intact.
5X troubleshooting steps can't be completed because the vehicle is inop.
  • Posted 26 Sep 2019 19:30
  • By john_blase
  • joined 26 Sep'19 - 18 messages
Showing items 1 - 20 of 26 results.
is there a way to test lpa and tpa, because code have pop out of nowhere. i was doing hydraulic oil change and when i restared it there was code 5a and 59. i have follow manual test always lead me to change lpa and tpa. Can someone help me out?
  • Posted 2 Apr 2026 21:15
  • By Eric_Loranger
  • joined 2 Apr'26 - 1 message
  • Canada
I have no power to both my amps
  • Posted 9 Jul 2022 00:58
  • By Todd_Powell
  • joined 21 Jun'22 - 6 messages
  • Minnesota, United States
Tpowell
What does relay k3 do
  • Posted 9 Jul 2022 00:27
  • By Todd_Powell
Tpowell
No problem! Glad to hear you got it!
  • Posted 8 Oct 2019 04:16
  • By Service_T
  • joined 5 May'18 - 91 messages
  • Kansas, United States
ServiceT
Thank you for all your time and efforts!
You were right! I took the AMP connections apart and one of the pins was slightly damaged! I just had to crimp it with a pair of needlenose pliers and presto!
Back in business!
Thanks again!!
  • Posted 7 Oct 2019 19:41
  • By john_blase
john blase
Well that makes sense,I am still waiting to get an updated flashware so I can get a better idea,i only know PAT are all showing 0.00,once I update the flashware i should have a better idea.
  • Posted 5 Oct 2019 22:45
  • By john_blase
john blase
They may have voltage but if a component is not talking it shuts the system down. I use the VERSIONS to see who the truck can see. If you have your inputs but no output that is usually a sign of a failed component. Like I said before I would have a Raymond dealer hook the computer up to it before throwing in part at it.
  • Posted 5 Oct 2019 10:23
  • By Service_T
ServiceT
At this point i am stumped because it appears that voltage is being supplied from the tm to both amps but they dont power the contactors.
  • Posted 5 Oct 2019 09:47
  • By john_blase
john blase
are these resistors located inside the amps?
  • Posted 5 Oct 2019 09:40
  • By john_blase
john blase
CanBus system with just 2 120 ohm terminating resistors should read 60 ohms between Can Hi and Can low. Can voltage varies depending if at idle or talking.
  • Posted 5 Oct 2019 06:53
  • By Service_T
ServiceT
I took the battery out and cleaned the battery box,there was electrolyte build up all over the bottom and it ate through the paint and some of the metal.I got a better look at the static straps and both are rusted and neither is touching the ground,I placed another grounding wire on top of one but no change.
I will try the horn and strobe next time.
Not sure I follow you on the CAN hi Can Lo,could you please clarify?
I got 2.5 volts when I checked the CAN voltage,not sure about the high or low value.
Thanks for taking the time to reply and for the tips!
  • Posted 4 Oct 2019 19:14
  • By john_blase
john blase
  • By john_blase
john blase
You could add another drag cable to it. Or ohm them out. The stud should have a resistor in it. But I really doubt that is your problem. You just want to make sure they are touching the ground. You could try unplugging the horn and strobe also to see if they are back feeding. Whats your resistance between Can hi and Can low?
  • Posted 4 Oct 2019 07:51
  • By Service_T
ServiceT
The static straps are rusty,i cant lift the raymond to fully access them, is there way to attach something to them that would help to check if it is the st
atic straps?
  • Posted 4 Oct 2019 06:38
  • By john_blase
john blase
CaBus low voltage should be 2.2 -2.5 volts. CanBus high voltage should be 2.7 -2.5. Another thing to check is static straps. I don't think it would be the display because it's talking. If your ID1 pin in the TPA plug isn't seated properly it can confuse the system not letting it know which node it is. I would recommend having the Raymond dealer hook up to it. You will need them to program what ever component you end up replacing.
  • Posted 4 Oct 2019 03:06
  • Modified 4 Oct 2019 04:31 by poster
  • By Service_T
ServiceT
I checked the BUS voltage and have 49 volts from the battery to JPTA 1-1 and Jpla1-1
Have 2.5 volts at pin 23 same at the splice.
I have to renew my Flashware so I can take a look into the system and see if there is anything else going on but it looks like both the amps are receiving voltage but something is preventing them from actuating the contactors,it shows 5a when turned on but does pass the self test but then goes to error code 59. Do you think the display module could be an issue as well?
Thanks
  • Posted 3 Oct 2019 18:37
  • By john_blase
john blase
I would check my Bus voltage with reference to DGND at the TPA
Verify K3 relay is good on the relay card.
Verify no pins on the TPA plug have been pushed out.
Connect to truck via flashware. (Try to find out why you cant see the TPA)
  • Posted 2 Oct 2019 08:02
  • Modified 2 Oct 2019 08:03 by poster
  • By Service_T
ServiceT
both the amps flash yellow then they flash red.
  • Posted 2 Oct 2019 06:31
  • By john_blase
john blase
It looks to me like you have a problem with your Traction Power Amp not communicating. Does the LED flash?
  • Posted 1 Oct 2019 23:30
  • Modified 2 Oct 2019 00:13 by poster
  • By Service_T
ServiceT
I pulled up versions and the PAT,PATB &PATVCL are all showing 0.00.
everything else has numbers.
The battery was also dirty and losing voltage across the top but I cleaned it up, still getting code 5A and 59 though.
I am leaning towards the TM, since it supplies the LPA and TPA.
Haven't gotten a chance to check the voltage going into the Amplifiers from the TM yet.
Any other ideas?
Thanks
  • Posted 1 Oct 2019 20:13
  • By john_blase
john blase
edition #1281 - 14 May 2026
Taylor TE650S
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
