Thanks I'll check it out tomorrow ??
hi mate
error A 5034:
Pump motor overheated, motor is too hot: Check temp sensor and wiring carefully,check external fan,
I suggest you can touch the motor when error occured and see if it's hot or not, If it's hot then check fan and earth leakage of pump motor,
If pump motor is ok when error occured then problem should be come from temp sensor and wiring
Check the engine high temperature pump, check grade ventilation, and rotation sensor.
att.
