Toyota 8FGCU15:
error code
customer has a 8FGCU15 with an intermittent shut off - no restart
showing an error code of ES-9 or E5-9
any help would be appreciated
  • Posted 10 Apr 2014 03:31
  • Discussion started by 67Malibu
  • Oklahoma, United States
I'll definitely look at those possibilities! Thank you so much!
  • Posted 4 Jun 2014 08:24
  • Reply by paul10
FO-2 - EHPS Abnormality
Current flow in motor although TMPS is NOT on. Basically the unit is seeing current flow through the steer motor without the unit actually being on.
There is a fault somewhere in your steering system. There are numerous possibilities. Things to check:
Battery voltage
Key switch
Check the power steering wiring
The other checks require opening the PS Controller. Only a skilled technician should attempt it. 36/48 Volt forklifts are dangerous and severe shock can occur. Checking for voltage on wrong terminals can also fry your multi meter as well as the main forklift controller. Hope this helps...
  • Posted 4 Jun 2014 07:02
  • Reply by LTS1
can you tell me what the code fo-2 is onf a 7fbcu25?
  • Posted 4 Jun 2014 02:38
  • Reply by paul10
Neither of the codes you have provided are legit. Please check code again and reply.
  • Posted 14 Apr 2014 10:11
  • Reply by LTS1
Linda Häkkilä Linda Häkkilä
