Hyster W40Z:
Error code
Ser # B218B10736D Hyster power worker
Customer called with a code AL10 ( version EP 107 ) and will not drive or lift.
Batteries fully charged, fuse checked out.
  • Posted 6 Apr 2014 04:54
  • Modified 8 Apr 2014 08:01 by poster
  • Discussion started by BrewCrew
We`re here for a good time
brew crew I have email you error code list
  • Posted 28 Sep 2018 05:41
  • Reply by redbull
  • Queensland, Australia
please check battery voltage under load and if you have flood type battery check each cell for volts per cell.
if you have the 4 6v batterys need to remove and check each battery under load I have seen batterys have failed.
if you have another unit there with the same battery volts plug into unit and see if unit operates
  • Posted 28 Sep 2018 05:38
  • Reply by redbull
Thanks for the clue - I will test each coil to see if one is faulty. Do you have any technical documents for this unit? My machine is actually a W25ZC. Another clue is that the led red light is flashing.
I bench tested the main relay by applying 24 volts and it seems to work fine.
Thanks very much for any assistance.
  • Posted 27 Sep 2018 12:39
  • Reply by heritage
HTI
AL04 is a problem with the lowering coil. Check all wiring. AL10, as stated it can be a number of things. First thing is checking for proper battery voltage. Make sure to check voltage with key on. Look for a voltage drop below 20 volts when key is turned on.
  • Posted 20 Sep 2018 23:08
  • Reply by BREWSKI
Hello , I am also having this AL 10 code - looking for a solution. A clue might me that if I lower the handle and turn the key it first comes up with an AL 04 code and then after a bit triggers the AL 10 code. Would greatly appreciate your incite!
  • Posted 20 Sep 2018 07:50
  • Reply by wayne_d
if the battery is plugged in and the unit's brakes do not hold (they release, when the battery is plugged in, not related to the handle switch/sensor) then code al10 can be the brake bypass has been plugged in so the unit can be pushed without dragging/skidding the drive tire.
  • Posted 18 Jun 2014 20:03
  • Reply by edward_t
For future reference... Bad Zapi, not sure if the unit`s worth fix`n
  • Posted 18 Jun 2014 07:15
  • Reply by BrewCrew
Thanks for all the info regarding the Zapi controller Swoop, will put it to good use and update what I find.
  • Posted 19 Apr 2014 06:03
  • Reply by BrewCrew
AL10 can mean several things
flight systems has information on zapi controllers but if they dont have the model controller you have then check your mail, i send you a list i have on this one.
  • Posted 16 Apr 2014 21:33
  • Reply by swoop223
After talking to Wajax they said the only way to decipher this code is with a hand set.
Does anybody know if this is true ?
  • Posted 16 Apr 2014 07:08
  • Reply by BrewCrew
St. Louis, MO, United States
Jefferson, WI, United States
Johnston, IA, United States
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
Toyota 8FGCU25
