error code
Don't have a service manual on this lift. Looking for description of error code F18 - potential causes & resolutions
  • Posted 24 Mar 2017 04:48
  • By kathleen_h
  • joined 24 Mar'17 - 3 messages
F18 - ECU KWP2000 Communication Error
Situation: Indication "F18" flickering, Drive Operations disabled.
Possible Cause: Faulty ECU, faulty gateway, faulty harness.
How the error code is triggered: When the KWP2000 communication from ECU to gateway is interrupted.
Checks:
Check the continuity of KWP2000 communication cable.
1. Between 719 (gateway) and 719 (ECU)
If continuity replace gateway, if error remains replace ECU.
If no continuity replace harness.
If i'm not mistaken there is a box mounted to the front engine compartment plate behind the operator cab area that contains the gateway, ECU and VCM3-0P, the cable and connections to test should be in there.
  • Posted 24 Mar 2017 22:21
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Taylor TT300
Hitachi HX64B2
