Error code intermittent 523524-3
Need some advice
  • Posted 12 Dec 2024 02:23
  • By Gusstone
  • joined 17 Apr'20 - 25 messages
523524-3 is usually tied to a fuel injector circuit fault. As Jose mentioned, check each injector connector and the ECU plug for corrosion or loose pins-disconnect/reconnect to clean contacts. If everything looks good, trace the harness for damage, as intermittent shorts or breaks can trigger that code
  • Posted 11 Aug 2025 17:09
  • By Asjad_Khan
  • joined 10 Aug'25 - 5 messages
  • United Arab Emirates
KUBOTA 3.8L DIESEL TURBO
  • Posted 11 Aug 2025 08:30
  • By Jose_alvarardo
  • joined 9 Aug'24 - 2 messages
Jose alvarado
Gus,
Remove each injector connector and inspect for corrosion. Do the same for the ECU connector 204. Remove and inspect for corrosion. I would slide the connectors on and off to ensure a good connection. The only other problem would be a failing wire harness. Good Luck.
  • Posted 17 Dec 2024 00:00
  • By Fishmech
  • Virginia, United States
Which engine is installed in the truck?
  • Posted 13 Dec 2024 00:37
  • By Slim99
  • joined 13 Dec'24 - 5 messages
SMV (Konecranes) 12-1200B
Terberg YT222
Bolzoni SpA (Group HQ)
Esie Cortez Esie Cortez
