Error Code E250
We run 4 toyota 8hbw23 walkie pallet jacks in my shop and on our trucks. One fell over in the truck and was loaded with corrosion as some of the water from the batteries got on the connections. It worked fine for a few months and we removed the connections and took a wire brush to the battery terminals to remove the corrosion. Went to turn it back on and got an error code of E250. Can't find anything online about this code. Has anyone dealt with this before? This happened yesterday(saturday) my dealer is not open. It kills me that the unit was running fine and then I took wrench to the terminals and a wire brush and now its not working.
  • Posted 15 Jan 2017 21:55
  • By nicholas_n
  • joined 15 Jan'17 - 3 messages
  • New Jersey, United States
Yes, my jack has the same code E-250 and looking for the battery problem.... I checked the power cables and connector and found out that all the batteries were dry, no water. I filled them up and put it to charge.... Now is working fine.
  • Posted 21 Apr 2023 23:28
  • By Rafa
  • joined 21 Apr'23 - 2 messages
Rafa69
Check your voltage at the connector. You will know if you have the correct voltage or a wire crossed.
If you are trying to access trouble codes. Look at what kind of controller it has some codes are specific to their controller rather than the unit & model.
  • Posted 23 Jul 2020 06:58
  • Modified 23 Jul 2020 07:01 by poster
  • By Alvino_Revilla
  • joined 2 Jun'20 - 15 messages
new to respond on here, we are finding alot of new trucks with a poor connection at the charger positive, have to replace charger and a few needed can cables as well, our were burnt to melted....
  • Posted 23 Jul 2020 06:01
  • By 65mustang
  • joined 23 Jul'20 - 4 messages
  • Michigan, United States
65Mustang
Hi Everyone!
Has anyone dealt with the code E159 on a Toyota 8HBW23?
  • Posted 30 Jan 2020 16:12
  • By luis_v
  • joined 25 Feb'07 - 127 messages
  • Mexico
lvelasco@insercomm.com
Has anyone dealt with the code E152 on a Toyota 8HBW23?
  • Posted 8 May 2019 05:12
  • By josephine_b
  • joined 28 Jul'18 - 7 messages
  • United States
Josephine Basile
Had the same code E250 pop up. Could hear contactors clicking rapidly before code finally showed up. Voltage was at 22.5. My jack ended up having 1 bad battery (4 - 6volts), which when tested showed as having a bad cell.
  • Posted 28 Sep 2018 00:43
  • By darek_s
  • joined 17 Jan'13 - 27 messages
Any idea what's error 249?
  • Posted 22 Dec 2017 07:22
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
E250 is the charger in sleep mode. Plug it in for a few minutes to wake it up. If that doesn't work, check the display for a version from the charger. It could be a communication problem from the charger.
  • Posted 20 Jan 2017 02:00
  • By ramon_m
  • joined 30 May'14 - 42 messages
Toyota 8FG25
Terberg YT220
Bolzoni SpA (Group HQ)
