Error Code E-03
Need help on Code E-03
No hydraulics no Trans
Any help would be appreciated Thanks
  • Posted 30 Nov 2012 00:55
  • By grant89
  • joined 2 Jul'09 - 28 messages
  • Minnesota, United States
Would start with the seat switch, or operator presence switch. If this switch, which is under the seat, doesn't make up, you have no transmission operation and no hydraulics. You can unplug the harness and jump the switch out for test purposes. It is located on the right hand side of the seat.
  • Posted 17 Jan 2013 13:19
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Code E-03 is for ECM power supply circuit, no power to ECM for a predetermined time.I would first check the fuses and relays there might be a fuse/ relay box under the left hand foot step this is also where the VCM is. Ere will also be a relay Fuse box located next to the battery
  • Posted 30 Nov 2012 02:41
  • By kevin_t
Taylor XC300M
New - Sale & Hire
SMV (Konecranes) 33-1200C
Esie Cortez Esie Cortez
