error code 751 flashing
Flashing code 751.I need help with this code and what to check for?
  • Posted 10 Sep 2015 02:01
  • Modified 10 Sep 2015 02:02 by poster
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
So no air through either side right?
  • Posted 23 Feb 2022 09:46
  • By Jose_Felix
  • joined 11 Feb'22 - 1 message
Check for Vac. leaks, and the Fuel Trim Valves. You can Ohm them out should be 26+/- 2 ohms. If you can blow air through them then they are faulty and stuck open.
The fault code reads as Pre-Catalyst 02 sensor indicates extended lean operation. This is odd as the system is designed to run rich when something goes wrong with the fuel system.
  • Posted 5 Oct 2017 23:15
  • By sirthor1881
  • joined 15 Mar'11 - 24 messages
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
Taylor T650L
Mitsubishi Logisnext FD25T5M
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Bolzoni SpA (Group HQ)
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
