error code 7 band 91
have error code 7 contact maintenance and error 91 pump temp too high sn G108N07997E any ideas where to start and btw no password to access panel
  • Posted 17 Apr 2014 01:01
  • By liftv5
  • joined 5 Oct'13 - 33 messages
error code 7 is accelerator input voltage too high when key is first turned on
error code 91 is pump motor temp too high
first i would check the accelerator pedal sensor and make sure its returning completely when released.
as for the pump temp problem, verify the temp of the motor, use a temp gun
does this truck have any attachments on it? any sort of clamp?
generally if the temp sensor is bad it generates a code 43, since you didn't mention this code we can assume the motor is actually overheating for some reason.
  • Posted 18 May 2014 01:06
Taylor THC500L
SMV (Konecranes) SL37-1200A
