Raymond 537-CSR30:
Error code 4A
Unit is equippped with the Vechile Manager and flashing Error code 4A. Any help would be great.
  • Posted 24 Feb 2012 04:23
  • Discussion started by robin_f
  • Alberta, Canada
Code 4A NOTE: If Brake Release Switch (S12) is in service mode, Code 4A will
occur during Power Up SelfTest (POST).
Corrective Actions and
Checks
1. The "X" contactor or its wiring may be bad. Run test:
* O01 - Toggle the "X" Contactor
2. The auxiliary sense circuit may be bad. Run test:
* A09 - X Sense Voltage
3. Check the 15 amp slo/blow fuse in the B+ line filter. If it is open,
check the battery. If the battery has low voltage, consider raising the
cutout percentage in the Configure Mode to prevent the fuse from
blowing again due to a low battery condition.
  • Posted 30 Aug 2012 13:59
  • Reply by derrick_r
  • Utah, United States
Most likely blown fuse in line filter next to contactors. Usually caused by low battery voltage.
  • Posted 25 Aug 2012 11:53
  • Reply by barry_r
edition #1235 - 19 June 2025
UN Forklift FD30T-NJM1
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
Load Lifter 2414-8G
Toyota 8FGCU25
