Error code 16
Any body know what error code 16?
Thanks,
Bart
  • Posted 17 Feb 2013 15:02
  • By bart_b
  • joined 17 Feb'13 - 4 messages
Thanks for the info edward t. That does make perfect sense. I will go through all mine and check they are set for 48v. Thanks again.
  • Posted 28 May 2013 18:39
  • By BigT
  • joined 17 Mar'12 - 6 messages
big t, I see this most often on 48 volt batteries, when the battery is really discharged, and the truck's [GE} controls are set to a dual voltage default. setting the battery configuration setting to the actual configuration of the truck often cures this (it thinks it is a too hot 36 vdc battery, rather than a too dead 48vdc battery).
what is the nominal battery voltage of the truck's configuration.
  • Posted 8 May 2013 21:13
I deal with very old 55fctt's and 90% of the time when this code comes up the truck wont do nothing at all. We have to tow it to the changing station and replace the battery. We have noticed this happens alot when a cell starts or takes a junk on us. Crownie is also correct in his post also. The lifts I work on are approximently 18 to 20 years old lol.
  • Posted 8 May 2013 20:32
  • By BigT
I assume you've got it running now but for anyone else. fault 16 is battery volts too high , usually caused by opportunity charging. use the raise a few times, then unplug battery and start again
(code often gets confused with fault 15 volts too low)
  • Posted 22 Feb 2013 16:55
  • By crownie
  • Victoria, Australia
Hangcha FLDCXT160
JLG G12-55A
Hangcha FLDCXT160
JLG G12-55A
GemOne
