error code 11
Dear Sir,
Kindly note that I have a Caterpillar forklift model EC25K that display error 11, I highly appreciate your help in solving this problem knowing that the controller is GE brand part No. IC3645SR4W606MC2.
Thank you
Ahmad Hadrab
  • Posted 21 Dec 2023 08:02
  • By Ahmad_Hadrab
  • joined 16 Dec'23 - 1 message
  • Jordan
Ahmad Hadrab
Electronics Maintenance Eng.
Tel:00962797455088
error 11 has to do with the start circuit, the accelerator switch
if the switch is closed on startup it will code out this code.
i would check and make sure it is returning to neutral and the start switch is opening when the pedal is released.
troubleshooting says to check P1-3 (wire 15) and make sure it is not shorted to positive.
it also says to check for a defective card, check P1-3 to negative. disconnect the wire and check P1-3 to negative, it should read zero volts, if not replace card.
  • Posted 23 Dec 2023 12:23
SNORKEL A46JE
Terberg YT220
Lift Tek Elecar
UN Forklift FBR25NQC3
Nichiyu FB28PN77B367RRC
US confidence index rises sharply Washington, DC, United States
Uxbridge, Canada
St. Louis, MO, United States
Evansville, IN, United States
Daleville, IN, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
