Error 444 cont communication problem
Hi got a k1b1r18u in for battery issues getting this error after RPL any ideas
  • Posted 4 Feb 2020 22:59
  • By Matt_es
  • joined 4 Jul'19 - 3 messages
  • Ireland
Matt
Probably fixed this but for future reference. Models 1b1, 1b2, a1n1
Code 444 can come from either a defective meter panel or a defective controller. Do Not swap parts with a known good truck to test as you have a 50/50 chance of swapping the wrong component.
A defective meter panel or controller with code 444 will rewrite the good controller or meter panel.
Test point for this code is on the traction controllers.
Connector 2 pin 12
Connector 2 pin 23 (should be an empty hole with no wire)
Infinity resistance between the two pins.
  • Posted 31 Jul 2020 12:07
  • By BLey
  • joined 31 Jul'20 - 60 messages
SMV (Konecranes) 4545CCX5
Enforcer FLBAXT25
