Error 36
Hi Team, I have a Jungheinrich EFG320 2005 model, serial no_ FN328402 with an error '36' (no lift sensor) can anyone give me any direction with this? everything works except for the lift function, If I pull another lever I can limp the lift into operating but it's not ideal. The pot is fine, and I can't find any broken wires. Direction please anyone? I don't have the software to diagnose it. The interface card is showing no error with a green LED, but if anyone can advise I would much appreciated it.
EDIT: PROBLEM FIXED, THANKS FOR ALL THE INPUT, TURNED OUT TO HAVE A LIFT CONTROLLER FROM A DIFFERENT TRUCK WHICH WAS LOOKING FOR A SOLO PILOT JOYSTICK, MODIFIED POTENTIOMETER RESISTANCE TO SOLVE THE ISSUE.
  • Posted 26 Aug 2023 18:34
  • Modified 23 Sep 2023 13:40 by poster
  • By Miles_Roberson
  • joined 26 Aug'23 - 4 messages
  • New Zealand
MilesR
Thanks Wayne, I have tried taking up the slack on the lever and also swapping out the potentiometer for a new one, (then swapping back the old) with no luck. Do you think it could help having the controls 'taught in' again by a tech?
  • Posted 4 Sep 2023 16:57
  • By Miles_Roberson
  • New Zealand
MilesR
Hi Miles,
Error 36 indicates that there is no zero position for the lift function, this means that the learned value for Zero/home of the lift lever potentiometer is not being met, it is possible that the lift potentiometer is worn thus the resistance is not what it was when it was 'taught in'
This symptom could also be caused by wear in the lift lever, if the lever now rests in a different position because of worn bushes for example,
Prove this by 'taking up the slack' on the lever when you start the truck up and see if it starts up without generating the error code.
  • Posted 4 Sep 2023 08:44
  • By Wayne_Young
  • joined 4 Sep'23 - 1 message
  • Auckland, New Zealand
WRY
thanks, will try.
  • Posted 31 Aug 2023 22:31
  • By Miles_Roberson
  • New Zealand
MilesR
try putting unit on charge full cycle, then when it is fully charged try the lift. make sure battery level is more than 80% charged.
if not put back on charge.
when the charger starts charging wait for one minute then turn off and re plug in to unit.
this should fix the problem.
  • Posted 31 Aug 2023 18:01
  • By alan_r
  • joined 12 Dec'08 - 2 messages
  • Australia
Alan Reeves
Check for speed limiting switch on side of the mast, if you google "Jungheinrich initiator" you'll know what to look for.
  • Posted 29 Aug 2023 23:56
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
Thanks for the reply, the micro switches for the levers are intact, however the lift lever only has a potentiometer, no microswitch for the lever that doesn't work.
  • Posted 28 Aug 2023 18:03
  • By Miles_Roberson
  • New Zealand
MilesR
If this model does not have joystick but levers, there are microswitches at the base of each lever. The wires are thin and sole may have been worn.
  • Posted 28 Aug 2023 14:32
  • By Tanel_M
  • Estonia
Esie Cortez Esie Cortez
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
UN Forklift FD35T-C2JB2
Hyster
Oxford Ct, United States
