ENGINE WILL NOT REV UP.
THIS ENGINE IS LP FUELED, WILL START UP AND RUN, BUT WILL NOT ACCELERATE. WE HAVE PUT SPARK PLUGS, WIRES, DIST. CAP AND ROTOR, BUT NO CHANGE. THERE IS AN ERR SHOWING ON THE HOUR METER, BUT NO CODE, JUST SAYS ERR. I AM OUT OF IDEAS. CAN YOU HELP?
  • Posted 6 Aug 2016 04:01
  • By cowboysteve
  • joined 6 Aug'16 - 3 messages
I did a little investigating on this machine, and after taking the throttle body(carburetor, if you will) off, I found another butterfly below it actually in the governor body. There is a little arm on the butterfly plate that is actuated by vacuum(or pressure), and it was almost broken off. I got some JB Weld and glued it back on. It was wobbling back and forth and getting out of it's little notch and then sticking so it wouldn't actuate the governor control. It runs great now. Thanks for inquiry, and I hope this helps.
  • Posted 22 Sep 2016 12:52
  • By cowboysteve
i've seen a few of these where the governor spring adjusting spring comes loose inside the cover.
I'm not saying anyone would be adjusting this (other than a yale tech) but if you do turn it too far in the wrong direction it will come unhooked from the mechanism inside it.
They have the wire seal on the adjusting screw & nut that should never be broken or missing during normal use, only a yale qualified tech should EVER adjust this setting.
Most of the time i found this wire missing where someone had been adjusting the engine speed to make the truck go faster.
Not a good thing :o/
  • Posted 19 Sep 2016 22:13
Hello,
Have you fixed it? I have the same issue.
  • Posted 19 Sep 2016 16:11
  • By Sebastian
  • joined 11 Nov'14 - 21 messages
  • Bihor, Romania
Thanks for the reply and input. I'll check this out. steve
  • Posted 7 Aug 2016 07:39
  • By cowboysteve
Have you looked in the throttle body to se if the butterfly is opening? Could also be a governor problem.
  • Posted 6 Aug 2016 05:20
  • By BREWSKI
Toyota 02-8FD30
Aichi RX07B
MAXAM Tire, Inc.
