Yale GLP060:
Engine Dies when lifting
I have a 1987 Yale GLP060RCJUAE086. When Lifting , the engine wants to die. Even if I throttle it up when lifting. Any help would be greatly appreciated. Thanks.
  • Posted 5 Dec 2020 01:39
  • Discussion started by Ed_Corsaro
that lift have an idle up dashpot on it?
generally when you load up the engine the dashpot will use the vacuum change and trigger the dashpot to push the throttle just a bit to keep it in a good power range so it won't stall out under a load from steering or hydraulic operation.
  • Posted 21 Dec 2020 04:17
  • Reply by swoop223
Some times the valves get a lot of build up in the intake side and this may be what is causing poor power
  • Posted 16 Dec 2020 03:05
  • Reply by stillworkin
Compression is very good..High 155 and low i 150
  • Posted 16 Dec 2020 01:08
  • Reply by Ed_Corsaro
do a compression check should answer all your questions or at least give you a better place to start
  • Posted 11 Dec 2020 01:54
It drives fine. When lifting it puts "strain" on the engine....pump dead heading?
  • Posted 10 Dec 2020 01:06
What happens when you turn the steering? Also what happens if you turn the steering completely to the right or left and hold it against the stop then try to lift?
  • Posted 5 Dec 2020 06:38
  • Reply by lifterfixer
It's like there is too much load on the engine. It drives fine unloaded.
  • Posted 5 Dec 2020 06:13
Hi Ed, you say it wants to die? Is it running out of power type of die, or is it just shutting off like you are turning the key off? Does it have plenty of driving power?
  • Posted 5 Dec 2020 05:07
Ncn 110TH
Ncn 110TH 2023
Terberg TT223
Combilift Ltd
edition #1234 - 12 June 2025
Your Focus
