Yale GLP050VXEGSE084:
engine cranks no power to coil
Ser#b875b03690d 2.4 gm lpg. Engine cranks no start. No power to ignition coil. New cam and crank sensor. Sent engine ecm out for testing came back with every thing good.engine has oil pressure 30 psi. On the left side of engine and transmission in the engine compartment there is a 5 prong wire connector that nothing plugged into it. It looks like there was a relay plugged into it. Harness has a tag on it #cps 206 any help is appreciated thanks
  • Posted 19 Mar 2025 01:27
  • Modified 19 Mar 2025 05:48 by administrator
  • Discussion started by jerryb
  • New Mexico, United States
jerry berg
Jerry,
CPS 206 is for a relay. Install relay into connector and see if truck starts. This supplies power to the ECU which send it throughout the engine. If you install relay and engine does not start, check fuse 6 inside the PDM. Should be a 20 amp fuse. Good Luck.
  • Posted 25 Mar 2025 00:57
  • Reply by Fishmech
  • Virginia, United States
Hangcha CBD15
China
USD1,600
Hangcha 78XEN
Flesherton, Ontario, Canada
Your Focus
Jefferson, WI, United States
St. Louis, MO, United States
Johnston, IA, United States
