Electrical Troubleshooting
Hello-
Need some help. I have a 2001 Hyster XL120 with a dual battery setup. I have replaced both batteries and the alternator.
When they key is in the "Off" position the alternator charging light stays on and won't go off.
Any suggestions?
Thanks
  • Posted 27 May 2020 01:58
  • By David_Griffiths
  • joined 27 May'20 - 1 message
  • Kansas, United States
David Griffiths
Maybe it is the regulator that is apart from the alternator mounted nearby.
The old alternators had no regulator mounted inside.
  • Posted 29 May 2020 04:06
  • Modified 29 May 2020 04:10 by poster
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
try disconnecting the small wires at alternator and see if light goes out , if it does your alternator should be checked out or replaced ?
  • Posted 29 May 2020 01:06
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
