EFG 115 from 2006 sn. FN346452
Hello guys,
I have a problem with the truck EFG 115 from 2006 sn. FN346452, the hazard led on the display is flashing, no error codes active but the truck is not driving.
Have any idea?
Thank you in advance.
  • Posted 9 Apr 2013 16:44
  • By Dejavu
  • joined 27 May'10 - 40 messages
  • Bucuresti, Romania
It may look like I'm doing nothing, but in my head I'm quite busy.
Hello
I was told you......
I have that a lot of time,ok good job.
Regards
  • Posted 12 May 2013 05:29
  • By nemanja_k
  • serbia, Serbia
Hello again,
I found the problem. The switch from the brake pedal was broken. The hydraulic switch from the brake pedal for this truck is normal close and when the brake the contact is open. From the bigining I was wrong because I supose that the switch is normal open :((.
Thank you for support.
Best regards.
  • Posted 10 May 2013 23:04
  • Modified 10 May 2013 23:05 by poster
  • By Dejavu
I was write you on your mail,check it.
Regards
  • Posted 14 Apr 2013 06:44
  • By nemanja_k
  • serbia, Serbia
Hello again guys,
I've changed the drive pedal with a new one.
I've checked the wires and voltages and the micro switch for the drive pedal and there is no problem there. If the pedal is pressed when the truck initiate then we get a error for the switch.
The seat switch is OK and also the wires are OK. Trying to drive without the seat active we get the info 090.
The hand brake if is active on the dashboard the red LED is on.
The inverter is OK (changed wit the one for hydraulic system).
When I press the drive pedal on the drive motor we can measure the frequency and is increasing but the voltage is only around 2v compare with the pump motor the voltage goes around 12 volts.
The dive motor is OK (I connect the outputs for the pump motor to the drive motor and is working).
The direction switch on the lifting/lowering lever is OK. I can see on the dashboard when is changing.
So, no driving and no errors on the dashboard.
(now I have the wiring diagram and the error list).
Any idea what could be the problem??
Best regards.
  • Posted 12 Apr 2013 19:45
  • Modified 12 Apr 2013 20:30 by poster
  • By Dejavu
Hello,
Thank you both!
I'll try all that things tomorrow and I'll tell you what I'll find.
Best regards.
  • Posted 10 Apr 2013 03:37
  • By Dejavu
yes , seat switch must be made
parking brake must release off of switch
accelerator pedal returning to neutral completely?
generally anything wrong, even these things will throw a code when direction is selected and an attempt to move is made.
  • Posted 10 Apr 2013 01:39
Hello nemanja,
Please check your email.
Thanks.
  • Posted 10 Apr 2013 00:45
  • By Dejavu
Hello
Do you have any info on display maybe?Are you see display and direction arrow when you select drive direction.Did you check hand brake and acceleration pedal?Seat react when you are on truck.
  • Posted 9 Apr 2013 23:58
  • By nemanja_k
  • serbia, Serbia
Muncie, IN, United States
