Economy 3000 scissor lift
I recently purchased an older Economy 3000 scissor lift Model 2046
I think it was built around 1980.
I'm having trouble finding a manual for it, if anyone happens to have one I would like to purchase a copy.
Can't find anything on the internet.
Thanks Bill
  • Posted 29 Dec 2020 04:46
  • Discussion started by KBConstruction
  • Michigan, United States
Showing items 1 - 15 of 15 results.
Thanks for help found the problem on the diode board, lift works great now.
  • Posted 18 Jan 2021 10:40
  • Reply by KBConstruction
KBConstruction,
if you look page 1-7 (figure 1-8) that is the standard operators control console.
no joystick
Now if you go down one page to page 1-8 (figure 1-9) that is the Optional Operators Control Console, it has a joystick.
So you have the optional console if it indeed has one.
  • Posted 3 Jan 2021 14:14
  • Reply by swoop223
Thanks I'll try that when I have time. I don't know what you were reading but this unit does have a joy stick. Yes i do have an electrical and mechanical background just not a lot of experience with lifts. It does save time to ask questions from someone that happens to have experience, the electrical world is very vast and one can never stop learning.
  • Posted 3 Jan 2021 13:27
One of the easiest thing's to do is swap the right and left wires on the valve. If the problem switches sides then it's electrical. Usually the Microswitch in the controller goes out, but since u have no controller and only toggles, I would say it's in the canon plug or cable.
  • Posted 3 Jan 2021 06:30
  • Reply by Scissor_God
Scissor God
Shadow722@live.com 209-846-5836
yeah, i actually took some time and went through this manual and of course it is not going to be like other machines you normally see like JLG or Genie or skyjack.
Apparently the standard operating console does not have a joystick, that is an optional control which i find odd. But never the less troubleshooting goes the same.
If he has any hydraulic/electrical skill at all he should be able to figure this out.
If he does not?
He shouldn't be working on this period.
  • Posted 3 Jan 2021 05:21
  • Reply by swoop223
There was only 1 manual for it and it covered a variety of lifts. But first I would like you to call me if you could. It easier then this.
  • Posted 3 Jan 2021 02:48
Scissor God
I downloaded the 585654 Manual
  • Posted 3 Jan 2021 01:54
My contact info is in here.
  • Posted 2 Jan 2021 10:59
Scissor God
KBConstruction,
if you have right turn but no left turn i would first check the circuit in the joystick steering switch, then go to the hydraulic control valve solenoid that controls the steering, it should be a 2 way valve with 2 solenoids mounted on it.
make sure both solenoids are good and the signal is getting to the solenoid when you select the left turn on the joystick.
The problem could be in the joystick, the harness from the platform control to the ground somewhere in it, or something at the solenoids.
If your getting actuation electrically then it could be a bad valve. You can pull it out and check the orings on it to see if any are broken/cut.
The manual should show you which valve is which and also should be able to help you with the joystick too. BTW, which one did you download?
It will require some reading though ;o)
  • Posted 1 Jan 2021 17:47
  • Modified 1 Jan 2021 17:48 by poster
  • Reply by swoop223
Found the manual at Snorkel web site. I could use some troubleshooting help.
Installed 4 new batteries and re-lugged all the battery terminals. Did some much needed cleaning. Everything works now except turning left.
  • Posted 1 Jan 2021 11:19
Thanks found it appreciate your help.
  • Posted 1 Jan 2021 11:14
I found it and am down loading now.
  • Posted 31 Dec 2020 02:56
Scissor God
KB_Construction,
can we assume this is an Snorkel/Economy 3000 Model 2046 scissorlift?
you can find their manual on snorkel's website
i'm looking at one right now, but need to have a serial number to get the correct manual but that shouldn't be too hard to find.
  • Posted 31 Dec 2020 02:03
  • Reply by swoop223
Do you need help fixing something?
  • Posted 30 Dec 2020 15:30
Scissor God
I should be able to get what you need when I get into work in the morning.
  • Posted 30 Dec 2020 15:29
Scissor God
edition #1235 - 19 June 2025
Harrisburg, SD, United States
Ottumwa, IA, United States
Wentzville, MO, United States
Unicarriers FHGE35T5S
UN Forklift FBT20NQZ1
