Eagle Pitcher Mast needed
I have a customer with a RT802WD with a gynormous mast, lifts 362". The down height is causing problems. I need a mast that still can lift 17-18 feet without being too tall to fit though a door!!
Thanks all---
  • Posted 6 Jan 2012 06:57
  • By TheBirdman
  • joined 20 May'11 - 47 messages
  • Oklahoma, United States
You can email me at:
guido AT liftking DOT com
  • Posted 7 Jan 2012 01:03
  • By Liftking
  • joined 6 Jan'12 - 14 messages
TheBirdman,
Your 362" mast is a 3-stage with a lowered height of 164" (under 14'). A 17' door wouldn't cause any problems - please measure.
Is the ground flat/level where you drive through the door?
  • Posted 7 Jan 2012 00:03
  • By Liftking
TheBirdman,
You need to advise what is "the clear door" opening in terms of inches. Don't think it is 17'. if the user only needs to lift 16' or 17'.
And it would be helpful to know what is the load size & weight the user wants to lift @ 16-17' feet & what loads they need to lift at lower elevations.
  • Posted 6 Jan 2012 12:12
  • By johnr_j
"Have An Exceptional Day!"
17 foot or less I am sure. This customer only needs to lift 16 or 17 feet. It does have sideshift. Throw some ideas my way Sir...
[email address removed]
Thanks
  • Posted 6 Jan 2012 08:28
  • By TheBirdman
What size door do you need to go through? I'm sure we can supply you with a mast. Liftking now manufactures the Noble RT80, which used to be CAT/EP.
  • Posted 6 Jan 2012 07:35
  • By Liftking
Muncie, IN, United States
Deborah Baker Deborah Baker
