E82 and E11
Im having trouble with an Atlet UFS250. It seems like it is in serious limp mode.
error code E82 is coming up on the dash, when looking at the error list it diverts me to error code E11 which says 'NVR partly reset' and the probable cause is 'electrostatic discharge' and to be honest I don't have a clue where to start.
The truck drives but has very very weak hydraulics.
  • Posted 4 May 2021 23:55
  • By Robbiej
  • joined 11 Jul'19 - 1 message
  • United Kingdom
First of all verify the options and settings in the menu and see if is meet with the values from the factory table (must have a documentation under the engines boonet or chair..
But the best option is to make a factory reset and then introduce the parameters, ONLY IF YOU HAVE THE DOCUMENTATION I WAS SPOKE PREVIOUSLY.
  • Posted 20 Jan 2022 17:08
  • By vanoss
  • joined 1 Nov'17 - 43 messages
  • Bihor, Romania
GemOne
East Syracuse, United States
Columbia, SC, United States
Saratoga, United States
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
