have a e30xm2 hyster with harness damage need a diagram to help with repairs
would be greatfull for any help
the main (drive) controller is where your bdi is regulated from, the pump controller is just a slave controller that works only the pump, it is however tied into the logic so when the bdi sees a predetermined low enough voltage it will shut down the pump operation and make you go charge the battery.
is the pump drive module the lift interupt also
e30xm2 d114v05149x sem controler
We need a full serial number also so we can get you the right diagram and schematics
What is the driving system, EV100 or SEM?
