E-34 CODE
We have E34 code , can anyone from the forklift brotherhood help.
Thanks in advance!!!
  • Posted 28 Apr 2012 00:44
  • By tony_s
  • joined 26 Apr'11 - 13 messages
Easy fix no one has talked about on this thread caused by making an easy mistake when not paying attention while installing a coil. I have nissan cls60 and I was getting the same code 34. Found one coil was not working correctly from unplugging them all 1 by 1. When I got to the one in question it didn't change the way the lift was running. So changed it out with 3 different ones I had laying around. Still didnt fix the missfiring problem. Turns out the mechanic that worked on it put the coil in and missed the spark plug. And I did the same thing 3 times. I finally looked more carefully and used my hand to push it up to not miss spark plug. And then started it up and it ran great. Problem solved. Hopefully this helps people out.
  • Posted 22 Jul 2022 00:45
  • By Gator
  • joined 3 Oct'14 - 45 messages
Jeremy If you don't mind, what was the problem with your lift? Thanks
  • Posted 21 Feb 2015 02:37
  • Modified 21 Feb 2015 02:39 by poster
  • By matthew_o
  • joined 21 Feb'15 - 2 messages
  • Colorado, United States
I am having the same problem. Tied starting the lift on one coil. lift does not start on any one coil. plug all of them in and it runs rough, start unplugging one by one, lift dies after two unplugged. getting code e34 on the dash, ignition signal circuit malfunction. Help Please. Thanks
  • Posted 21 Feb 2015 02:36
  • By matthew_o
hI I have the same problem how did you clear the erroe code ?
  • Posted 17 Jan 2015 00:09
  • By richard_m
  • joined 11 Apr'13 - 111 messages
  • lancashire, United Kingdom
search this website's forums for "pedal dance".
  • Posted 14 May 2014 07:53
I created code E-34 I unplugged a coil pack then started the engine. I know what the problem is, but how do I clear the code?
  • Posted 14 May 2014 04:29
  • By jeremy_g
  • joined 14 May'14 - 1 message
  • Vermont, United States
We will do that. Many thanks and greatly appreciate your time on this.
I will let you know if this works !!!!
  • Posted 28 Apr 2012 03:45
  • By tony_s
tony:
Both the crank & cam shaft sensors are sending signals to the ECM. The way to ck the coil packs is as follows: Removing 3 of the 4 coil packs at a time. The engine will run on 1 individual coil and eventually smooth out. Repeat this step till you have tested each coil to run the engine. When the engine dies on a specific coil, replace the coil, clear the code and run the truck to check your work. Good Luck and Good Service to you.
  • Posted 28 Apr 2012 03:37
  • By MEngr
  • Missouri, United States
In your experience , how would the coil pack br tested and is there a sensor to be checked also. Does the crank sensor send a signal to the computer to fire the coil pack ?
  • Posted 28 Apr 2012 02:46
  • By tony_s
Hi tony;
The answer to your question is E34 is saying that the Engine Control Manager (ECM) is not seeing an ignition input signal continuously while the engine is running. This signal is generated by the coil packs and is sent to the ECM.
  • Posted 28 Apr 2012 01:50
  • By MEngr
UN Forklift FGL25T
Toyota 8FD45
Lee Rushton Lee Rushton
