e-3000 ac speed control
Not looked at this truck yet but can you slow these down so operator cant change through dash?Also has anyone had pump failures with this unit?
  • Posted 10 Nov 2009 01:27
  • Discussion started by proshadetree
  • Tennessee, United States
Thank you Ed these units rip the splines off the pump.Customer said it was rusty on the splines
  • Posted 10 Nov 2009 10:03
  • Reply by proshadetree
you are far more likely to have a clogged up relief valve in the main hydraulic control valve or motor turning too slow than a pump problem but there have been some. (not many) be sure you have an A/C clamp on amp gage when you go to check it out, to insure the amps are good, as well as the pressure.
As I remember it, with the laptop (or the D-R-S switch), you can either set all the setups for a slower speed, or you can set the unit up as an EE unit and that will prevent higher speed, and higher amps on a ramp, and prevent the changing of the speed with the dash
  • Posted 10 Nov 2009 08:08
  • Reply by edward_t
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Advance CS7000
Illinois, United States
USD8,000
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Terberg YT182
Airman ENCL045
MAXAM Tire, Inc.
Hangcha CBD15
China
USD1,600
Ncn 85TH
Ncn 85TH 2017
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
