Gc50 lpg truck First visit to truck wouldn't start found spark plugs at fault replaced and cleaned dis cap out starting fine.couple of days later wouldn't start no fault code flashing.gas good to reg.LPG solinod working found no gas coming out off reg.then truck was starting up but sound like not firing on all cylinders then it will be OK for the rest of the day.
Next DAy in morning truck started up used to 10 mins then they parked truck up went to start truck wouldn't fire up turning over went in truck fired up but not picking up like not firing on all cylinder when going the rest of the day working fine no problem starting and running.next couple of days fine then started to have this fault again
took apart unit and there was traces of coolant in unit and gas pipe.
plus removed top of throttle unit and traces of coolant there as well.
after along time getting the parts woodward parts are more expensive than impco parts.put it all back together and no further report of problem
Give them a call if need be. thanks
Doosan Forklifts
12 Kilvey Road, Brackmills Industrial Estate
Northampton, Northamptonshire
NN4 7BQ
Phone: 01604 825600
If this unit has the Woodward fuel system i would check for possible coolant leak internal to the regulator and being drawn into the mixer. I have also ran across where the spark wires burn internal to cable. Let us know what you find.
