Doosan (& Daewoo) G30P-3:
Doosan G30P overheating
We have a G30P that seems to run very hot all the time. Radiator is pretty clean. No leaks noted. Would a replacement high flow or slightly cooler thermostat help?
  • Posted 1 Jun 2016 00:50
  • Discussion started by KBlackPronto
  • Oregon, United States
hi KBlackPronto,
a cooler range thermostat may help
But... in some cases engines are designed to run around the 195 deg temp range. If you are having an overtemp issue with the engine though, try the lower range thermostat, if that does not help i would verify that the water pump is circulating coolant in the radiator, sometimes poor circulation can cause overheating due to a worn out water pump. Also make sure the radiator flew's are clear and no buildup of anything on them. Bad airflow and even foreign material built up on the flews can act as a inhibitor preventing the radiator from dissipating heat correctly.
One other thing to consider and is often overlooked, are the cooling ports in the engine open and clear, it is difficult to check this because of the bypass circuit in the cooling system at the waterpump. You can try doing a cooling system clean out by flushing out the system with a cooling system cleaner.
If all of the above still doesnt help and it still has a tendency to overheat there are cooling system addetives you can put in the coolant to help keep it cool, we use what is called 'enginkool' and also change the coolant to dexcool.
Another alternative is using a regular extended life coolant (not as good as dexcool but does help in some cases), but i would definatly get some of that 'enginkool' addetive, it works wonders with stubborn overheating problems.
  • Posted 1 Jun 2016 22:18
  • Reply by swoop223
edition #1228 - 1 May 2025
