Crown WAV50-118:
does not power up
Having problems with no start up, battery displays turns on but does not stay on, changed controller, contactor, connector plugs. Checked for shorted conductor cable all ok, need help. Thanks
  • Posted 24 Apr 2013 07:39
  • Discussion started by All Lift Tech
What is the battery voltage?
Connect a meter, turn the lift on, and watch the meter.
  • Posted 27 Apr 2013 13:14
  • Reply by Liftdoctor
  • Indiana, United States
man, are you checking any of these parts or just replacing them? The diode blocks are not what i was talking about. there is a diode on the contactor coil.. physically on the terminals of the contactor coil.
does the contactor close then open immediatly? or not at all?
  • Posted 25 Apr 2013 07:49
  • Reply by stam
found CAN fault by connecting Curtis controller, don't have manual
  • Posted 25 Apr 2013 05:14
  • Reply by All Lift Tech
No luck replaced ed switches and diode blocks
  • Posted 25 Apr 2013 02:11
Thanks for the tip stam. will update later
  • Posted 24 Apr 2013 08:26
if all the epo circuit is ok, check the diode on the line contactor, make sure it is not giving the coil a dead short. it being on backwards can simulate this.
  • Posted 24 Apr 2013 08:05
  • Reply by stam
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Autolift E180AT36B-D5-180
Ncn 85TH
Ncn 85TH 2017
TCM FD80Z7
TCM FD80Z7 1990
UN Forklift FGL35T
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
