Display Trouble
The truck will key up and everything works. I have this message on the Display. (Waiting for Download Command). That is all it will show and I can not get into the settings.
  • Posted 17 Dec 2015 02:24
  • By Brad1110867
  • joined 3 Nov'15 - 15 messages
Thank you very much for the help. That fixed my problem.
  • Posted 19 Dec 2015 03:13
  • By Brad1110867
ok i will give that a try. Thanks
  • Posted 19 Dec 2015 00:15
  • By Brad1110867
The lift select button is on the left handle.
Same place as the horn button on the right handle.
I didn't read your post properly. Your truck is operational so all that needs to happen is a configuration download as I described.
Hold both deadman down. Key on with right hand and use left to push lift select 3 or 4 times before the truck starts selftest. Some guys just keep pushing the button fast. There is some timing to it but it's not like the pedal dance on a cat or anything.
You'll get it.
  • Posted 18 Dec 2015 12:16
  • By stam
Yes, I am very familiar with sa/sb 96/9700 537 589 and TRT.
I didn't mention that you have to keep the deadman pedals down.
Push lift select button 3 or 4 times within 3 or 4 seconds.
If this does not work unplug the bus cable from the display interface card and see if it drives. If it does you need an interface card.
  • Posted 18 Dec 2015 09:19
  • By stam
I did this but nothing changed. Also this is a Turret Truck so i did all but push the button i hit the lift switch 4 times but made no differance.
  • Posted 18 Dec 2015 05:54
  • By Brad1110867
Try programming the display.
Step on both deadman. Key on and push lift select button 3 or 4 times, this will run configuration download. It will code 57. Turn off then try to drive normally.
  • Posted 17 Dec 2015 20:53
  • By stam
Toyota 4FD240
SMV (Konecranes) 4545CCX5
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Toyota 4FD240
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Philadephia, PA, United States
Chandler, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
