Depressurising the clamp while holding the paper roll
I have a problem with the rotary grabber of lift truck, sometimes when it has got the paper roll it looses and falls down it. Unfortunately I do not have it's hydraulic circuit and I have no idea where is the problem, I have checked the cylinders and they works without leakages.
  • Posted 23 May 2024 03:45
  • By Sajad_Rajabi
  • joined 23 May'24 - 13 messages
  • Iran, Islamic Republic Of
Kind regards
S.Rajabi
I dont know anything about that clamp but the company that builds that clamp has distributors all over the world l did find one that might be able to help you that is not that far in turkey maybe they can get you or direct you were to get a hydraulics digram to check it out there number is+902164704660 it is called Fama forklift kaup turkey hope I was of help
  • Posted 25 May 2024 11:24
  • By Scott_
Scott
Thanks for comment.
It's kaup 2T013
  • Posted 25 May 2024 06:20
  • By Sajad_Rajabi
Kind regards
S.Rajabi
Thanks for your response,
It's kaup 2T013, if I had it's hydraulic circuit I could figure out where is the problem, it's cylinder doesn't have check valve on pressure port.
There is a block on clamp I must know what's going on inside it.
I should to add, it happens randomly not always. And it makes it scary.
Where should I find the hydraulic diagram?
  • Posted 25 May 2024 06:18
  • By Sajad_Rajabi
Kind regards
S.Rajabi
I dont know what clamp this is but most manufacturers install lock valves inside the cylinders just incase the packing or the valve is leaking internally after the clamp is shut closed the valves hold the cylinders so not to drop the rolls and kill someone l know if it is cascade clamp the valve are set at around 900 psi to open on the back stroke it is possible that the valves in one is going bad just thinking but you will have to take pressure test to see were the problem is
  • Posted 24 May 2024 21:39
  • By Scott_
Scott
If it's a Cascade clamp, they have service manuals online.
cascorp dot com/us/en/serviceliterature
  • Posted 24 May 2024 00:08
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
Terberg RT403
Nagano NUZ090D
Terberg RT403
Nagano NUZ090D
