Datsun PF02 A25V (5000 #) Hard Starting/Running Rough
Initial problem was with not starting, but got that corrected with a new vaporizor-regulator. Then still had the problem so I bypassed the fuel lock(vacuum) and managed to get the lift running. The fuel lock seems to be working but not getting enough vacuum from the carb.
I think if I can get the carb tuned up it will give the fuel lock the vacuum it needs and also fix my hard start/rough running issues.
Any advice on getting the mixture screw set? And what should the idle be set at?
Thanks.
  • Posted 7 Sep 2011 02:05
  • Modified 7 Sep 2011 02:07 by poster
  • By vman
  • joined 7 Sep'11 - 5 messages
I think your problem lies in fuel delivery. Remove lpg mixer and place a shop rag over intake opening. Make sure that all lockwashers and nuts are accounted for and none entered intake. disassemble mixer watching to not destroy gaskets and notating orientation of components. Give all parts a good cleaning. Inspect diaphram for holes/tears if older model mixer. Make sure all orifices are cleared and rotate the lean/reach mixture adjustment full range while spraying cleaner into the inlet. Be sure to clean throttle bore well around butterfly. Do not remove butterfly to shaft screws. Just clean well around it using small brush with cleaner. Use compressed air to blow out after cleaning. Lean/ rich adjustment pointer should be one click left of midway point initially. Idle adjustment will need to be reset. Back out idle air mixture screw till maximum idle rpm is achieved. You should be good to go. That should take care of the "bad" smelling exhaust fumes also.
  • Posted 13 Nov 2011 03:21
  • Modified 13 Nov 2011 03:33 by poster
  • By RCAV8TOR
  • Alabama, United States
I found TDC on #1 by using a screwdriver in the plug hole and turning the engine over by hand. Set the static timing. With the timing set the ignition system side was done. Tweaked the carb some and got the lift to start up. A
litte fine tuning with the timing and setting the idle speed and it'll be running like a dream.
Mrfixit, thanks for all your help.
  • Posted 11 Sep 2011 12:20
  • By vman
So I pulled the plugs, cleaned and gapped them. Getting good spark on the plugs and checked the coil with a spark tester and it jumped a 1/4 in. with no problem. Set the point gap. I'd like to set the timing but can't figure out how to get a view of the crankshaft pully. The only way I can think of is from underneath. but getting the lift up isn't an option I have.
Anyhow, I had someone turn the engine over while I moved the dist. around and still nothing.
Even with the timing being off I would still expect some attempt to fire.
Any ideas?
  • Posted 10 Sep 2011 04:07
  • By vman
I guess the next step is to take the plugs out and visually see if they're sparking. If not then check to see if there is power to the coil and clean the points.
  • Posted 8 Sep 2011 05:54
  • Modified 8 Sep 2011 05:55 by poster
Compression checked out. Tried some starting fluid but don't get even a stumble. May be an ignition problem. Set the points at.018 according to specs for the nissan H20 engine, I'm assuming there's no difference on the points between gas and LPG.
  • Posted 8 Sep 2011 04:55
  • By vman
I checked for vacuum leaks by spraying carb cleaner around the carb and didn't notice any increase in RPMs.
As for the valve clearences, not sure what they should be set at. I haven't been able to find any specs for this lift.
A compression test would indicate valve clearences being off, right? Bad comp. = Bad vacuum...?
  • Posted 7 Sep 2011 10:46
  • By vman
You might want to check the rocker arm /valve clearances if it's running rough. That would cause low vacuum also and cause the fuel lock valve not to turn on. Maybe check for any bad gaskets on the carb and manifold too.
  • Posted 7 Sep 2011 06:49
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Autolift E180AT36B-D5-180
Terberg RT403
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
Terberg RT403
CEO, Robust.AI
