Daewoo GC30P Serial # 3FR00279
Getting a code 73, engine will shut down as if you turned the fuel off. Dash light comes on but lift will continue to run sometimes and sometimes not. Does anyone have a code list for this lift that I can get. Thanks for the help.
  • Posted 23 Jun 2010 05:24
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
The code 73 is AFR trim valve Upper DC.
It states FTV duty cycle at highLimit (Rich)
Check wire to trim valve, look for hose blockage or off, feel the trim valve while running and you should feel it clicking if you rev the engine it should click faster. we do replace the trim valves alot. they get gummed up and fail.
good luck
  • Posted 9 Jul 2010 03:54
  • By allan_m
  • joined 3 Jul'09 - 14 messages
  • Washington, United States
phat al = amixon@midcoforklift.com
Does anyone have the code listing for these lifts. Local dealer will not help with this. Thanks for the help.
  • Posted 28 Jun 2010 22:02
  • By garland_m
