DAEWOO G30E-3 BRAKES AND STEERING BINDING IN HYD SYSTEM
The steering is binding and the engine will hardly run sometimes. If we disconnect the pressure line from the pump going to the brake apply cylinder, we still have pressure on the steering cylinder even though it is bypassed. it acts like the pump is back feeding the return lines. This is a convoluted system and we cannot find any information any where. Any ideas??
  • Posted 30 Sep 2025 02:40
  • By Ricky_Gilmore
  • joined 12 Feb'22 - 12 messages
rgilmore
Well a big Thank to Andreas as the o-rings on the fittings for the priority valve were dry rotted and causing bleed over from port to the next binding the pump. We changed the o-rings and all is well.
  • Posted 18 Oct 2025 02:09
  • By Ricky_Gilmore
rgilmore
miltonforklift @ yahoo com
  • Posted 10 Oct 2025 06:57
  • Modified 10 Oct 2025 13:19 by administrator
  • By Ricky_Gilmore
rgilmore
I have all books on pdf and can send you by email. Just give me your email address.
  • Posted 5 Oct 2025 03:04
  • By andreas_k
  • joined 22 Nov'09 - 6 messages
  • NRW, Germany
A book with flow charts and/or hydraulic schematics would be wonderful. Do you have it in digital form and can email it?
  • Posted 4 Oct 2025 06:20
  • By Ricky_Gilmore
rgilmore
Hello Ricky,
it seems you have a problem with the steering gear or the priorityy valve. I have a manual and spareparts book to share with you, if you want.
Kind regards
Andreas
  • Posted 2 Oct 2025 20:18
  • By andreas_k
  • NRW, Germany
Ncn 110TH
Ncn 110TH 2015
JLG G12-55A
