Cylinder issue
I have an issue where the free lift cylinder doesn't get all the way up but the second stage starts to go up. Any suggestions?
  • Posted 8 Oct 2021 02:06
  • By ChrisCrown
  • joined 7 Oct'21 - 3 messages
  • Virginia, United States
If it only does it at high speed then check the flow regulator valve in the bottom of the carriage cylinder. I've had many of them fail.
  • Posted 11 Oct 2021 14:38
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
make sure the retaining clamp on the first stage cylinder has not been overtightened
make sure your secondary chains are adjusted correctly
adjust mast anti rattle grub screws, including 2 hidden ones at the bottom
ensure mast channels are clean and lightly greased
  • Posted 9 Oct 2021 10:19
  • Modified 9 Oct 2021 10:20 by poster
  • By crownie
  • Victoria, Australia
Do a complete reseal on the free lift cyl
  • Posted 9 Oct 2021 07:47
  • By Triggs
Autolift E180AT36B-D5-180
Terberg RT223
Terberg RT223
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
