crown stacker
l just picked up a crown ctacker model w2t-90-s serial l-8295 and lm looking for information on it it did not come with a charger it has a sticker of 24volts so l bought one automotive style it can charge 12 -24 volts l than checked the batteries there 4 6 volt batteries which would make up the 24 volts listed but when l measured the batteries the most l could come up with is 12 volts lm just looking for general info on this unit like specs and a wiring schematic was told this was an old unit but l dont know how old it is thanks in advance for any help Dan
  • Posted 12 Sep 2022 22:30
  • Modified 15 Sep 2022 19:36 by poster
  • By Daniel_Nurnberg
  • joined 11 Sep'22 - 3 messages
ok so l just bought a service and parts manual for a 20mt because l was told that thay were the same as the manual for my machine which is a W2T-90-S now l get a phone call that someone found the correct manual for 299 dollars what l need to know is the electrical and parts manual the same or at least close enough thanks
  • Posted 14 Oct 2022 00:29
ok that makes sense l was told that the unit runs in 12 volt but when you switch it to rabbit mode it than goes into 24 volts which makes sense but what l really need is a manual service or electrical do you know where l can get one or both l tried crown and thay told me it was an old unit good luck thanks Dan
  • Posted 23 Sep 2022 19:49
charger is 12volt approx 25amp
2 batteries in series
and 2 groups in parallel
  • Posted 22 Sep 2022 19:24
  • By crownie
  • Victoria, Australia
Taylor T520M
Mobicon 2T
