Crown RC5530 Wont move but goes up and down says right pedal left pedal
Keeps telling me right pedal i move foot around then says left pedal will not travel at all....steering up/down and sideshift all work any ideas?
  • Posted 20 Jun 2020 23:47
  • By kingkuality
  • joined 21 May'17 - 61 messages
You need to recalibrate the handle bro. Some switch is out of range. Also you can see the switch if dead or not in calibration mode.
  • Posted 9 Nov 2020 14:39
  • By Chermike_Ouano
  • joined 8 Nov'20 - 6 messages
  • Philippines
I assume you've gotten this going by now, but I just had this same experience. The thing that solved it for me was to turn the key on to the start position from the outside of the machine BEFORE standing on the pedals. Then get in and stand on the pedals as normal and away it goes.
  • Posted 15 Sep 2020 11:34
  • By Vegastime1
  • joined 13 Dec'18 - 10 messages
Check and calibrate multitask handle. Check to see if fwd/rev optical switches are working. Also had that condition when the potentiometer on the foot pedal was out of spec
  • Posted 23 Jun 2020 00:25
  • By Ifixit
I will check them today or soon thanks
  • Posted 22 Jun 2020 23:33
  • By kingkuality
have you checked your optical switches to see if one is sticking on?
  • Posted 22 Jun 2020 23:02
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
