crown c5 not start engine
it does no start and it does not present fault code. The access 3 ECU CARD was changed and programmed.
the crankshaft sensor is changed
the air throttle actuator is changed
the EPR was replaced
And the forklift still does not start. Please can any one help me
  • Posted 7 Apr 2019 06:23
  • Discussion started by miguel_g
  • ESTADO DE MEXICO, Mexico
HI MY RIEND I HAVE A C5 AND I NEED PROGRAM THE ECU IS POSSIBLE YOU HELP ME THANKS
  • Posted 20 Aug 2022 13:17
  • Reply by CJHURT
  • Mexico
HOLA AMIGO DONDE LA PROGRAMSTE TENGO UNO QUE OCUPA PROGRAMACION TU ME PUEDES AYUDAR SALUDOS
  • Posted 20 Aug 2022 13:16
  • Reply by CJHURT
  • Mexico
send email
  • Posted 15 Apr 2019 01:07
  • Reply by prepaito_d
  • iztapalapa, Mexico
Check to see that the oil pressure sending unit wire is still attached. It is located near the engine oil filter.
  • Posted 15 Apr 2019 01:02
  • Reply by mwjski
  • Montana, United States
Jefferson, WI, United States
Johnston, IA, United States
St. Louis, MO, United States
edition #1234 - 12 June 2025
