Crown 40FCTT-188, flashing yellow light on battery charge indicator, No drive no lift
Crown 40FCTT-188; S/N: 9A121797; 36Volt; Battery condition is good and voltage is 38.08 or 2.11 volts per cell.
Turn key switch to green, display reads "key" as normal. Turn to yellow, all lamps illuminate and display reads "test" as normal. Release switch, return to green and the yellow battery symbol lamp at the base of the green battery state of charge lamps flashes steady on off. Nothing on the display readout, no drive operation, no lift operation. When seat switch is closed I can hear relay click. When park brake is released and seat switch is open the alarm sounds as it should but display does not read "brak". Same when direction lever selected forward or reverse and park brake applied, display does not read "DIR". Once the battery symbol begins to flash the display reads nothing.
This is an intermittent issue and truck will resume normal operation sometimes if I open, then close the battery disconnect and restart the lift. It does not always work though.
Does anyone have a digital copy of the service manual for this lift truck? If not I plan to order one but it is a few weeks out says dealer.
  • Posted 6 Aug 2021 14:32
  • Modified 7 Aug 2021 02:25 by poster
  • By GRUtah
  • joined 6 Aug'21 - 1 message
  • Utah, United States
Is het probleem gevonden?
wat was de oplossing? ik heb hetzelfde met een 3 ton
  • Posted 4 Jan 2024 07:40
  • By peertje
  • joined 3 Jan'24 - 2 messages
  • Netherlands
123 forklift
usually the large 300 amp cartridge fuse in the back is blown
  • Posted 24 Jul 2023 17:36
  • By crownie
  • Victoria, Australia
GRUtah did you ever find the source of this problem? I'm having the exact issue with the exact forklift. Thanks.
  • Posted 14 Jul 2023 06:21
  • By Mike_Cammack
  • joined 14 Jul'23 - 1 message
Mike
If you are certain it is not a battery issue then I would take a look at your battery retainer switches. I have seen a similar problem like this many years ago but cannot remember exactly what fixed it. I have also had a bad control card as well as a faulty Curtis lift interrupt. I always try to eliminate the battery by either swapping it out or using a battery extension cable.
  • Posted 8 Aug 2021 13:20
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Airman ENCL045
Toyota 02-8FD25
