Crown 30RCTT will not lift
Hello i have a crown 30RCTT that will not lift. Contacts pull in pumps works. the tilt works the clamp that is connected also works opens closes side shift. i just can not figure out why up will not work. any suggestion will be great thank you
  • Posted 3 Sep 2021 00:59
  • By VIKINGS4life
  • joined 20 Dec'19 - 11 messages
Miguel
Swoop, nice write-up.
Also, look for a Curtis lift interrupt box. Many of those trucks had one. The Crown spec page did not list much of anything on this 30RC. If your lift motor does not engage when raising handle that could be a possibility. Keep us posted.
  • Posted 4 Oct 2021 13:53
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
if all functions work except lift this verifies your auxiliary part of the controls are working. If you pull the lift lever and hear the main pump startup then you know that is working. If you don't hear it start up check the switch or contactor.
On some of the older trucks they utilized the power steering pump for auxiliary hydraulic functions so that might explain why all your auxiliary functions do work but not the main lift. There is a distinct difference between the auxiliary and the main hydraulic, the sound would be obvious. The main pump motor would be very different than the auxiliary pump motor. (louder and more distinct).
Other possible causes:
your main function for lift is bypassing or working (not engaging) but you hear the pump motor start and run:
-i would check the main pressure relief valve and make sure the spring inside it is not broken.
-You also might want to put a pressure gauge on the main lift port and see what pressure it is getting if any, to verify. If the relief valve is damaged you will not get any pressure to the lift cylinder.
-Also if the splines on the pump shaft are stripped or the spider coupler is broken you would have no pressure, so, pull the pump off the motor and verify the splines/spider coupler are still in good shape.
  • Posted 4 Oct 2021 02:42
Does the lift pump motor run when you try to raise mast?
  • Posted 3 Oct 2021 15:14
  • By 1CrownTech
The serial number 1A135460
  • Posted 1 Oct 2021 07:33
  • By VIKINGS4life
Miguel
What is the serial number? I suspect your lift/lower solenoid valve is not opening. It's been about 10 yrs since I last worked on one and cannot remember where it is located.
  • Posted 3 Sep 2021 11:18
  • By 1CrownTech
Crown Equipment celebrates 80 years New Bremen, OH, United States
Evansville, IN, United States
Daleville, IN, United States
Uxbridge, Canada
St. Louis, MO, United States
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Uxbridge, Canada
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
