Cranks but No Spark
Hyster model: S120XL Serial D004V 06321P
Cranks fast but No Start and No Spark.
I used a spark plug tester, No Spark.
Replaced Cap and Rotor and Coil Wire (they were all corroded)
Replaced Coil.
  • Posted 27 Mar 2025 03:31
  • By PATWILL
  • joined 27 Mar'25 - 4 messages
  • Missouri, United States
PATRICK WILL
yep, corrosion in connectors will do it for sure.
usually when you replace the main components and that doesn't work then you go to the troubleshooting wiring and power path's.
the thing about corrision is once it's in there it's hard to get rid of it unless you replace all the terminals with new ones. If this tech did not do that then the problem will more than likely return one day.
  • Posted 3 Apr 2025 00:46
I called a forklift mechanic $165 an hour, after 2 hours cleaning corroded wire connectors he got power to the coil. Then another 1.5 hours of Cleaning more corroded wire connectors he got power to distributor and it fired up. Previously I installed new Ignition module, Distributor cap, Rotor, Coil and coil wire and a new fuse.
Mechanic said Ultimately it was the badly corroded wiring connectors.
Although the Cap and Rotor were Horribly wore away and corroded the worst I had seen.
Thanks for your help.
  • Posted 3 Apr 2025 00:24
  • By PATWILL
PATRICK WILL
Thank you, I need some time to check it out.
  • Posted 2 Apr 2025 00:49
  • By PATWILL
PATRICK WILL
Thank you, I need some time to check this.
  • By PATWILL
PATRICK WILL
since your talking cap and rotor i will assume this is the GM vortec V6?
you might want to check the oil pressure switch also, these will also kill the ignition if the switch is bad. just use a vom, put in ohms and read across the switch, crank the engine and it should close, if not then replace the switch.
most of the time you will see evidence of it leaking as well, sometimes they don't but always check that switch, it only takes a couple minutes and is an easy check and fix.
  • Posted 29 Mar 2025 23:43
Make sure you have battery voltage to coil if so remove cap there is a pick up coil inside check ohms the two wires it should be about 500 to 1500 ohms if OK than change the ingion modual in the distubuter. Good luck.
  • Posted 27 Mar 2025 23:26
  • By Scott_
  • joined 16 May'21 - 332 messages
Scott
edition #1281 - 14 May 2026
TCM FD80Z7
TCM FD80Z7 1990
Nagano NUZ090D
Nils Altrogge Nils Altrogge
VETTER Forks, Inc.
