Unicarriers (& Nissan) 4 CYLINDER LPG:
Crank to cam timing marks
need to find out if the crank to cam is the dot to dot or some other method, read the chain is supposed to be colored or marked in some way. mid 90s nissan 50 with H20 propane, Thanks in advance,
  • Posted 7 May 2011 12:27
  • Discussion started by Rj1984
  • Arizona, United States
Thanks for the info, so I assume with paint marks gone a person just lines up the chain with the dots in those positions. Tried to get this from the local nissan lift truck and needless to say not very helpful. Again thanks.
John
  • Posted 10 May 2011 12:50
  • Reply by Rj1984
Crank's timing gear dimple will be at the 12:00 O Clock position while the cam gear timing position will be at the 3:00 O Clock position with the paint marks on timing chain to match these positions.
  • Posted 10 May 2011 00:49
  • Reply by MEngr
  • Missouri, United States
edition #1235 - 19 June 2025
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
